Enhancements
ID |
Title |
Shape 26 for Rebar Shape BS 8666:2005, Leg A and (C) are now always following the rule | |
New Keyin for Reassign a new concrete owner for existing rebar is available | |
BS8666:2005_Shape Code 99 is now scheduling when the Shapes Rule deviates from Standard shapes | |
The Multiple Select mode is offered for Rebar Modification tools | |
Rebar Shapes of Shape Code BS8666:2005 are following the rule mentioned in the code | |
Bar Mark Macro is retaining the last saved settings | |
Length of rebar in callout is now always matching the length from Positioning results |
Resolved Issues
ID |
Title |
BarName is not re-appended anymore with "Bar Grade" and "Bar Coating" in Element Information dialog box. | |
Irregular Dispatch does not lead ProStructures to crash when the associated line string is modified | |
Single Rebar is now getting back to default color when using rebar modification tools on it | |
Multiple selection_Single rebar- Edit rebar modification tool is now working on multiple selection with Single rebar | |
Edit Rebar - Mixed Selection of rebars from various rebarset is now working for Rebar modification tools with Multi-selection | |
Schedule generator-Default text style can be set as ProConcrete2 | |
Multiple Selection with Edit rebar is now working on different RebarSets of same assembly | |
Levels and Colors of RebarElement which was customized are not reverting back anymore up on modifications | |
Single rebar - Bar Weight Property is now listed in Ms_Properties | |
By points -Rebar modification tools like Trim, Extend, break are now working with by points option | |
2D Rebar disappears when switching between drawing and design model using marker, back and forward buttons | |
Frames (Symmetric, Vertical & trestle) are now being copied or rotated by object work frame, copy is working | |
Irregular Dispatch - works while placing in a semi-circular solid with higher rebar size | |
Convert End Condition to Bend Bar Tool works now all times | |
H & K dimensions of Rebar shape 99 based on shape 29 is now in accordance of BS 8666:2005 shape code | |
Dimensions of cranked bars now always in accordance to Rebar Codes | |
No crashing when model is switched between 3d model and drawing by Section callout's icon | |
Column Circular Ties now always upgrading properly when opened in CONNECT Edition |
