| Application | PLAXIS 3D |
| Issue status | ✔ Solved |
| First Affected Version | PLAXIS 3D 2013.00 |
| Found in Version | PLAXIS 3D 2013.00 |
| Fixed and Released in Version | PLAXIS 3D AE.00 |
| Issue # | 19436 |
| Date created | 18 December 2013 |
In some rare cases, the Plaxis 3D 2013 Output program cannot open a phase result, and it causes an error message / bug report, or the Output program does not respond anymore. This can happen due to an incorrect initialization of a result type that is not even used in any result plot or table.
This issue is solved since PLAXIS 3D AE.00.
To overcome this issue when still using PLAXIS 3D 2013, we created a special patched version of the PLAXIS 3D 2013.01 Output program (Version 2013.01 build 10082). This is to replace the Output version that is part of the official release: Output Version 2013.01 build 9831. To replace it:
