Product(s): | ProStructures | ||
Version(s): | CONNECT Edition (10.XX.00.XX) | ||
Area: | Setup & Customization | ||
Subarea: | Ribbon Interface | ||
Original Author: | Vyanktesh Nama, Bentley Product Advantage Group |
The ProStructures CONNECT Edition ribbon interface typically follows the Microsoft Office ribbon with some enhancements. The following image shows the different components of a ribbon.
The size of the ribbon components automatically adjusts as you resize the product window. This adjustment also happens when you view the application on different screen sizes. You can also customize the ribbon.
For more information on this, please follow the below blog.
