| Product(s): | ProStuctures | ||
| Area: | Settings | ||
| Subarea: | Design File Settings | ||
By default, the Decimal accuracy for values is set to ‘0’. Hence, to increase the decimal accuracy for values in the connection dialogs, this must be done in the Design File Settings.
Follow the steps below to increase the decimal accuracy.
1. In the backstage of the application, navigate to settings>File>Design File Settings
2. Under Design File Settings, click on the working units category, and under Linear Units options click on the Accuracy option and increase the accuracy.
3. The set accuracy will also reflect in the connection dialog boxes and you can also enter fractional values for connections.
In this way, you can increase the accuracy of values in the connection and other dialogs.
