|  | Product(s): | ProjectWise InterPlot Organizer |  |
|  | Version(s): | N\A |  |
|  | Environment: | N\A |  |
|  | Area: | General |  |
|  | Subarea: | N\A |  |
During Database Setup of Digital Archive InterPlot the following error message appears
Attempt to connect to datasource failed
To create the System DSN on Windows Server 2008 64-bit, you must run ODBC in 32-bit mode by invoking c:\windows\syswow64\odbcad32.exe.
|  | Original Author: | Frank Reimann |  |
