| Product(s): | Bentley Substation CONNECT Edition |
| Version(s): | 10.03+ | |
| Environment: | N/A | |
| Area: | Installation_Configuration | |
| Subarea: | N/A |
The purpose of this document is to guide you through the deployment process of Bentley Substation CONNECT Edition. The deployment process involves the following steps:
- Download Bentley Substation CONNECT Edition
- Install Bentley Substation CONNECT Edition
- (Optional) Create a deployment image (refer to Bentley Substation Help > Deployment Guide)
- Create Project Database
- Create and Deploy a Shared Workspace
- Migrate V8i Projects to CONNECT
- Deploy Bentley Substation CONNECT to all users
1 Download Bentley Substation CONNECT Edition
Please refer to the article How to download the Bentley Substation software.
2 Install Bentley Substation CONNECT Edition
An administrator should install the software on one machine that they can use to initially configure the software and establish a shared corporate workspace further explained in step 4 below.
For instructions on installing Bentley Substation CONNECT Edition you can refer to the online Bentley Substation Help > QuickInstall Guide.
3 (Optional) Create a Deployment Image
If you want to create a software deployment image in order to facilitate the installation of the software across your organization then refer to the Substation Help > Deployment Guide topic for detailed steps on how to create this.
4 Create Project Database
To share projects among multiple users you will need to have SQL Server running on a network server. See the application’s readme file for SQL Server requirements.
To create a new CONNECT project database, you can refer to the article, “Creating and Updating the Project Database.”
To migrate your existing V8i projects to CONNECT Edition you can refer to the article, "Migrating Bentley Substation from V8i to CONNECT Edition."
5 Create and Deploy a Shared Workspace
The installer delivers two separate example workspaces for each electrical standard named, “Substation ANSI-IEEE Example” and "Substation IEC Example" which contains the standard symbol catalogs, parts database, page formats, templates, etc.
Important! Bentley reserves the right to modify the Example workspaces on new releases of the software. You must create and deploy a new corporate workspace that includes your custom content and templates rather than modifying the existing Example workspaces.
Creating a New Workspace
To create a new WorkSpace follow these steps:
- In Windows Explorer, make a copy of the ‘Substation ANSI-IEEE Example’ or Substation IEC Example' workspace which is located in this folder after a default installation of the software:
C:\ProgramData\Bentley\Substation CONNECT Edition\Configuration\WorkSpaces
Copy both the folder and the configuration file named, “Substation ANSI-IEEE Example.cfg” or "Substation IEC Example.cfg"
- Rename both the copied folder and the configuration file to a new name for your organization such as, “MyCompany.”
- Start Bentley Substation and from the Welcome dialog and select the “Start a Work Session” button
- Select the “WorkSpace Picker” and choose “Create WorkSpace” to create a new WorkSpace.
5. Enter a name for your workspace such as “MyCompany” and point the Root Folder path to the “MyCompany” workspace.
Customize the WorkSpace
By default, the dataset resides in the following folder within your WorkSpace:
…\MyCompany\Standards\Substation
The dataset is organized into the following subfolders found in the before mentioned folder:
- Catalogs
- Cell
- Config
- Databases
- DgnLib
- License
- PageFormat
- Quickstart
- Sample Projects
- Templates
You may delete any default content that you do not need from the dataset. For instance, you may have no need for the Sample Projects or specific catalogs.
If you have custom content from V8i that you would like to use such as catalogs, report templates, and other files you can copy them over to the CONNECT WorkSpace to the appropriate folder.
The following sections will explain in more detail how to add your custom content.
Symbol Catalogs
To ensure that the software loads your custom catalogs you must follow this twostep process:
- Copy any custom catalogs that you have to the following folder: …\MyCompany\Standards\Substation\Catalogs
- Ensure you set the ELEC_CATALOG_PATH variable to point to the above mentioned path.
Catalog Paths can be specified in one of two ways:
- Directly editing a configuration file
- Using the application’s interface
Set the configuration variable named, “ELEC_CATALOG_PATH” in a configuration file to point to the folder that contains your catalogs. All catalogs found in this folder will be loaded by the software. If you wish to load catalogs from different locations you can specify multiple paths delineated by a semicolon “;” when setting the value for the ELEC_CATALOG_PATH variable as shown below:
ELEC_CATALOG_PATH = $(_USTN_WORKSPACESTANDARDS)$(_USTN_APPLICATION)/Catalogs/;//MyNetwork/Catalogs/MySecondCatalog/
The two recommended places to specify your catalog paths are as follows:
- WorkSpace Level (MyCompany \ Standards \ Substation\ Substation.cfg): Setting catalog paths at this level of the configuration system will make the catalogs available to every WorkSet / Project that you create within this WorkSpace.
- WorkSet Level: Setting catalog paths here will make the catalogs available to this specific WorkSet and will take precedence over any value you set at the WorkSpace level. This could be specified in a Template WorkSet which is explained in the article Working with Template WorkSets.
Refer to the article Configuration Files for a greater understanding of the configuration files in the application.
- Select the Configuration Variables button in the Project Manager to open the dialog.
- Locate the ELEC_CATALOG_PATH variable and click the “…” button to edit it.
Parts Database
To configure your own parts database, you must follow this process:
- Create a parts database mapping configuration
- Set the ELEC_ACTIVEPARTSDATABASE variable
To create a parts database mapping configuration you must use the New/Modify project dialog. To access the dialog, you must first select a WorkSet in the Project Manager and then follow these steps:
- Select the Configuration Variables button in the Project Manager to display the Configuration Variables dialog.
- Locate the ELEC_ACTIVEPARTSDATABASE variable and select the Value pull-down and choose the option "<Configure Parts Database>."
- Click the New button to create a new parts database mapping.
- In the Add Parts Database dialog, enter a Parts Database Name such as “MyPartsDatabase.”
- If using a MS Access parts database file, you can browse to the file. If using a SQL Server table, you can Build the connection string.
- Select the table that contains your part records from the Table pull-down and click Next to continue.
- Map the fields from your parts database with the application’s internal field names. Refer to the application’s help file for more information on this feature if needed.
- When done mapping fields click the Finish button.
The parts database mapping is stored in this file:
MyCompany \Standards \Substation\ PartsDBMappings.xml
If you need to change the location of this file you can modify the value of the ELEC_PARTS_DB_MAPPING_PATH variable in the Configuration Variables dialog or by directly editing the WorkSpace configuration file (MyCompany \Standards \Substation\ Substation.cfg).
You must now tell the software to load the parts database mapping configuration that you just defined in the first step. This is done by setting the ELEC_ACTIVEPARTSDATABASE variable to the name of the parts database mapping configuration. If you want to ensure that the software uses this parts database for all WorkSets, that do not specify their own parts database, you must set this variable in the WorkSpace configuration file.
This can be done in one of two ways:
- Directly edit the Workspace Configuration file (MyCompany \Standards \Substation\ Substation.cfg) and set the variable as shown:
ELEC_ACTIVEPARTSDATABASE = MyPartsDatabase
- Using the application’s interface by opening the Configuration Variables dialog and locating the ELEC_ACTIVEPARTSDATABASE variable and setting the pull-down to “MyPartsDatabase.”
Default System Options File
To make changes to the default System Option settings in the software you can follow this procedure:
- Open a page of any Project.
- Select File > Options to open the Options dialog.
- Set the system option settings as desired and click the “Save (Disk Icon)” shown below to save the options file:
Give the file a name such as “MySystemOptions” and save it to your workspace here:
\MyCompany\Standards\Substation\Config\Options
- To specify this as your default System Options file set the variable ELEC_SYSTEM_OPTION_PROFILE to the name of your System Options file using the Configuration Variables dialog or by directly editing the configuration file (MyCompany \Standards \Substation\ Substation.cfg) and setting the variable as shown:
ELEC_SYSTEM_OPTION_PROFILE = $(AppWorkspaceStandards)Config/Options/MySystemOptions.xml
Default Project Options File
To make changes to the default Project Option settings in the software you can follow this procedure:
- Set your desired project option settings and click the “Save (Disk Icon)” shown below to save the options file:
Give the file a name such as “MyProjectOptions” and save it to your workspace here:
- To specify this as your default Project Options file for all new projects set the variable ELEC_PROJECT_OPTION_PROFILE to the name of your Project Options file using the Configuration Variables dialog or by directly editing the configuration file (MyCompany \Standards \Substation\ Substation.cfg) and setting the variable as shown:
ELEC_PROJECT_OPTION_PROFILE = $(_USTN_WORKSPACESTANDARDS)$(_USTN_APPLICATION)/Config/Options/MyProjectOptions.xml
- (Optional) If you have multiple project options files that you need for different projects, you can make use of a template WorkSet to set which Project Options file to load when using this template to create a new project. For more details, see the article Working with Template WorkSets.
Default User Options File
To make changes to the default User Option settings in the software you can follow this procedure:
- Set the user option settings as desired and click the “Save (Disk Icon)” shown below to save the options file:
Give the file a name such as “MyUserOptions” and save it to your workspace here:
- Edit the file you just saved (MyUserOptions.xml) in a text editor and Find the two lines that begin with <LogCommand> and <LogCommandPath> and replace them with the following:
<LogCommand>false</LogCommand>
<LogCommandPath/>
This will avoid setting a path that is specific to one particular machine for all users when you deploy the software to others.
- To specify this as your default User Options file set the variable ELEC_USER_OPTION_PROFILE to the name of your System Options file using the Configuration Variables dialog or by directly editing the configuration file (MyCompany \Standards \Substation\ Substation.cfg) and setting the variable as shown:
ELEC_USER_OPTION_PROFILE = $(AppWorkspaceStandards)Config/Options/MyUserOptions.xml
Profiles
The Profiles folder (\MyCompany\Standards\Substation\Config\Profiles) contains many sub folders for the various types of profiles or formats that are commonly used in the software as shown below:
- Address Files
- Device Cross Reference Formats
- Device ID Formats
- Drawing Standards
- Text Styles
- Wire Link Cross Reference Formats
- Wire Properties
- Wire Tag Formats
Copy your custom profiles to the appropriate folder above.
If you want to change the default location of the profiles, the variable ELEC_PRJ_PROFILE_DIR can be modified in the Configuration Variables dialog or by directly editing the configuration file (MyCompany \Standards \Substation\ Substation.cfg).
Multi-language Database
Copy your custom Multi_Language_UI.mdb to this folder:
\MyCompany\Standards\Substation\Databases
If you want to change the default location of the page formats, the variable ELEC_LANGUAGE_DB_PATH can be modified in the Configuration Variables dialog or by directly editing the configuration file (MyCompany \Standards \Substation\ Substation.cfg).
Page Formats
Copy your custom page formats to this folder:
\MyCompany\Standards\Substation\PageFormat
If you want to change the default location of the page formats, the variable ELEC_PAGE_FORMAT_DIR can be modified in the Configuration Variables dialog or by directly editing the configuration file (MyCompany \Standards \Substation\ Substation.cfg).
Templates
The Templates folder (\MyCompany\Standards\Substation\Templates) contains many sub folders for the various types of templates that are commonly used in the software as shown below:
You can individually change the default location of the template folders using the Configuration Variables dialog or by directly editing the configuration file (MyCompany \Standards \Substation\ Substation.cfg) for each of the following variables:
- ELEC_TEMPLATES_GRAPHICPLAN_DIR
- ELEC_TEMPLATES_PAGE_DIR
- ELEC_TEMPLATES_REPORT_DIR
Template WorkSets
In the CONNECT Edition, WorkSets can be used to apply configuration settings that override the WorkSpace. If you have a need to frequently change settings on a project basis you can define separate WorkSets for each project. In such cases, it can be advantageous to take advantage of template WorkSets to drive the creation of a new WorkSet. By doing so you can apply project specific settings to any new project that you create. Here are some typical uses for a template WorkSet:
- Specify a project specific catalog or parts database.
- Load a specific project options file.
You can add Template WorkSets to your workspace by following the instructions in the article Working with Template WorkSets.
Deploying a Shared Workspace
Once you have defined your own corporate workspace you will want to deploy this workspace to a shared network location so that all your users can access it. This is achieved by following this procedure:
- Move or copy the “MyCompany” workspace and the MyCompany.cfg configuration file to a shared network location such as:
\\MyServer\Workspaces\
- Locate the “WorkSpaceSetup.cfg” file on your local machine which can be found here after a default install of the software:
- Edit the file in notepad or any other text editor and locate this section of the config file:
# Assume MY_WORKSPACES_LOCATION variable points to your desired network location like
#MY_WORKSPACES_LOCATION = //MyNetwork/MyWorkSpaces/
#%if defined (MY_WORKSPACES_LOCATION) && exists ($(MY_WORKSPACES_LOCATION))
# _USTN_WORKSPACESROOT = $(MY_WORKSPACES_LOCATION)
#%endif
- Remove the ‘#’ sign to uncomment the script lines and then specify your network path as shown below:
MY_WORKSPACES_LOCATION = //MyServer/Workspaces/
%endif
- Restart Bentley Substation to connect to the new workspace.
6 Migrate V8i Projects to CONNECT
Important! Before migrating your projects from V8i to CONNECT Edition it is highly recommended that you make a backup of our V8i Project Database and the V8i project files.
To access your V8i projects in the CONNECT Edition you must perform the following tasks:
- Use the Configuration Assignment Utility, which can be accessed in the Project Manager, to assign a CONNECT configuration to your legacy V8i projects.
- Update your V8i project database schema to the CONNECT Edition Schema using one of the following methods:
- A SQL Server administrator can manually execute the update script file provided with the software here:
C:\Program Files\Bentley\Substation CONNECT Edition\Substation\Electrical\SqlScripts\SQL_UpdateDB.sql
- Use the Project Database Utility > Update Project Database tab to execute the Update Script file from within Bentley Substation. The utility is accessed from the Project Manager by selecting the "Configure Databases" button and selecting the "New Database" button.
7 Deploy Bentley Substation CONNECT to All Users
To deploy Bentley Substation CONNECT across your organization, you should perform the following tasks:
- Install the Bentley Substation CONNECT Edition on all your user’s machines. If you created a deployment image you can make use of that to expedite the installation process. You should be able to install CONNECT alongside your V8i installation if you wish.
- Copy the WorkSpaceSetup.cfg file that you customized in section 5 (Create and Deploy a Shared Workspace) to each user’s machine, replacing their existing files. The file is located here if using a default installation:
You have now successfully deployed the application.
