Applies To | |||
Product(s): | MicroStation | ||
Version(s): | 08.11.09.459 | ||
Environment: | N/A | ||
Area: | Cells | ||
Subarea: | General | ||
Original Author: | Maria Munoz, Bentley Technical Support Group | ||
How to create web pages HTML format with cells images from my cell libraries
Instructions:
1. Menu Utilities\HTML Author-> select Cell Library->ok
2. Select Cell library-> Open
3. The dialog opens (select your required settings) -> Accept
4. Create HTML file opens (you can modify library directory or image directory)-> Accept
If you turn on Display File in Browser you will be able of previewing the results.
Note: Example: in my case the directory where acadterm.html was created was D:\workspaces\MicroStation\MS 081109459\Workspace\System\cell\acadterm.html
http://communities.bentley.com/products/microstation/f/142/t/69514.aspx
http://communities.bentley.com/products/microstation/f/19565/t/78382.aspx
