| Application | PLAXIS 3D |
| Issue status | ✔ Solved |
| First Affected Version | PLAXIS 3D 2018.00 |
| Found in Version | PLAXIS 3D 2018.00 |
| Fixed and Released in Version | PLAXIS 3D CONNECT Edition V20 |
| Issue # | SW-35825 |
| Date created | 19 February 2019 |
| Date modified | 19 August 2019 |
Node-to-node anchors and fixed-end anchors are directly connected to structural elements (plates, beams, embedded beams) at the location of their connection. However, in PLAXIS 3D 2018 when:
that the structural connection between the anchor and the plate in this prestressing phase is not always properly applied. This results in wrong force transfer from the prestressed anchor to the plate element, and consequently might lead to incorrect deformations due to missing force connection of the anchor’s prestressing.
Note that this issue happens only during a prestressing phase in PLAXIS 3D 2018. In the case the anchor is not prestressed, the connection between the active plate and active anchor works as you would expect it to be.
The issue is resolved for PLAXIS 3D CONNECT Edition V20
This issue is now solved with PLAXIS 3D CONNECT Edition V20!
Whenever you use this prestressed anchor connected to plate elements in PLAXIS 3D 2018.01, please make sure to check the force transfer between anchor and plate and verify that it is properly connected during this prestress phase.
