| Application | PLAXIS 2D |
| Issue status | ✔ Solved |
| First Affected Version | PLAXIS 2D AE.00 |
| Found in Version | PLAXIS 2D AE.00 |
| Fixed and Released in Version | PLAXIS 2D 2015.00 |
| Issue # | 21970 |
| Date created | 06 August 2014 |
When applying load factors according to the design approaches in PLAXIS 2D AE, we do not always see the applied LoadFactorLabel for the design approach in either the Selection explorer, or Model explorer, or both.
This issue is now solved since PLAXIS 2D 2015.00
As mentioned above, this behaviour may be confusing in PLAXIS 2D AE, as such we will explain below how to use the command line to inspect the actual settings in the project. In this example the aforementioned confusing behaviour is shown using PLAXIS 2D AE's Tutorial Lesson 8, and focus on Phase_9:
As can be seen in the image above, inside the Selection explorer the LoadFactorLabel, and design values for the load components (q_x,design and q_y,design) are not displayed for the selected load. In the image above these parameters are shown in the Model Explorer. However, it could be that this is also hidden in the Model Explorer.
To inspect if and when a Design approach LoadFactor has been assigned to the line load, we can use the command line to access this information:
To change the load factor label via the command line, we need get the following information:
We can then set the design approach label using the following command:
set Lineload_1_1.LoadFactorLabel Phase_9 LoadFactorLabel_3
Then we can check the changes via these commands:
echo LineLoad_1_1.LoadFactorLabel
echo LineLoad_1_1.qx_start_design
echo LineLoad_1_1.qy_start_design
The above mentioned process has been animated, see below:
Unable to display content. Adobe Flash is required.
Note: This issue is now solved since PLAXIS 2D 2015.00
