| Version(s): | V8i | ||
| Area: | Visualization | ||
| Subarea: | Render | ||
| Original Author: | Craig Calvin, Bentley Technical Support Group | ||
Where are rendered images and associated Luxology temporary files saved to?
The location where created images are stored is defined by the configuration variable:
MS_IMAGEOUT
Temporary files are stored at the directory defined by the configuration variable:
MS_TMP
Configuration Variables in MicroStation V8
Product TechNotes and FAQs
Bentley Homepage
Bentley LEARN Server
