| Product(s): | InRoads | ||
| Area: | Tools | ||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
When selecting an XML Geometry Report, the stationing format is not correct, how can this format be changed within the report?
Within the Bentley Civil Report Browser, select Tools>Format Option and select your desired station format at the Station Mode Format. Notice, the format in the report has been changed to reflect your desired format.
