| Version(s): | 08.01.00.00 | ||
| Area: | Custom Linestyles | ||
| Subarea: | N\A | ||
How to drop all Custom LineStyles in a file
Product: MicroStation
Version: V8 and V8i
Area: Custom Linestyles, Drop Linstyle
With the CSV remapper, go to the LineStyles Worksheet and enter:
%unmapped
into the LineStyle column.
Enter %drop into the OutputLineStyle column corresponding to the file format to which you are saving.
For example, if saving to DWG, enter:
%drop
into the DWGOutputLineStyle column.
This will drop all LineStyles (even if they are supported in DWG).
