In this Playlist you will learn various skills and techniques for using Bentley's BIM solution, OpenBuildings Designer, to model a structural slabs and foundations.
This playlist contains videos for in depth learning in order to model key structural elements using OpenBuildings Designer.
To view the complete course and download a workbook, visit the Bentley Learn Server.
1: Creating a New Model FileIn this first video we will get started by creating a new model file for the slabs and foundations of the building. | https://youtu.be/01o5d29a1sk |
| https://youtu.be/vr-k38_SPPc |
2: Attaching Reference Models with the ExplorerIn this next video we will use the Explorer dialog to reference the structural frame model to the new slabs and foundations model. |
3: Place Slabs By BoundaryIn this video we will model the ground floor slab using the boundary method. | https://youtu.be/g6yMISiJXTM |
| https://youtu.be/cuPQoDJj5Ig |
4: Place Slabs By Structural MemberIn this videowe will use the structural members in the framing model to define the slab edge and model the slabs of the upper floors. |
5: Place Slabs Between Concrete BeamsIn this video we will again place slabs using the boundary method. We will also apply a clip volume to the model to clip the model so that we can focus our work on a small portion of the entire model. | https://youtu.be/oXaiEu2ndSA |
| https://youtu.be/iAd2ON0jOoM |
6: Modeling Slab PenetrationsIn this video we will use the Object tool to add slab penetrations for the stairs and elevators in the building core. |
In the next video we will use the Concrete Column tool, changing the catalog item in the Property Panel to Foundation | Concrete Pier.
7: Modeling Spread FootingsWe will set the Family and Part to Foundation::Spread Footings. So, in this respect we utilize the placement tool for our placement options and DataGroup properties, and utilize the Family and Parts to designate the spread footings. | https://youtu.be/t88ZA85K3q8 |
| https://youtu.be/gw8YNRfQd2g |
8: Modeling Strip Footings and Structural WallsIn this video we will model strip footings and structural walls for the basement of the building. We will use the Floor Selector to set our Z elevation utilizing the ACS Locks to place the top of the strip footings and the bottom of the walls at the proper Z elevation. |
Parent topic: Getting Started with Structural Essentials
