| Version(s): | All | ||
| Area: | Load-case | ||
Nov 2014, AutoPIPE V8i 09.06.01.10
How to perform a Pressure analysis in AutoPIPE?
AutoPIPE performs a pressure analysis when the following settings are enabled:
Load> Static Analysis sets> select and modify any analysis set> Enable the check-box to the left of "Calculate pressure extension cases, e.g. P1, P2, etc" as shown below:
Please see the online help for details on this option / setting.
"Pressure" - AutoPIPE load case
