Inserting Multiple Records in Pro
If your data entry defaults have been set up correctly, you can add multiple rows by repeatedly clicking the INSERT key on your keyboard. This is ideal for data entry for repetitive items such as blow counts for dynamic probes. The image below shows the result of hitting the INSERT key 14 times on the Dynamic Probe entry screen. Once these records are inserted you can simply use the arrow keys and the keyboard to quickly enter the blow counts.
