(For assistance with any of the items below, please contact support or your OpenGround Implementation Manager.)
Once you have joined the Bentley Developer Network, we will provide you with a “sandbox” cloud for developing your API integrations, as well as any relevant SDK’s and code examples.
You will also need a Client ID, and potentially a Client Secret, depending on the Authentication method you will be using.
Client Credentials Authentication
For Client Credentials (Machine) authentication, you will need to create a user in your sandbox cloud with the appropriate access levels assigned. Assign the user a generic (fake) email address. It shouldn’t be an actual user’s email. The Client ID will be linked to this user's profile.
If you are developing multiple apps, create a user in the sandbox cloud for each app.
Let us know:
We can then provide a unique Client ID and Client Secret for each app.
When you are ready to move your app to production, let us know, and we can link your Client ID to your production cloud.
User Login (Authorization Code) Authentication
For User Login authentication, when working in your sandbox cloud, you can use the generic Client ID:
openground-cloud-connector
A Client Secret is not needed for User Login authentication.
When you are ready to deploy your app in your production cloud, let us know:
If desired, a unique Client ID can be requested for use in your sandbox cloud with User Login authentication. Once you're ready to deploy your app, this Client ID can be linked to your production cloud. This may be useful so you can use the same Client ID across both environments.
