| Product: | STAAD.pro | ||
| First Affected Version: | 21.03.00.146 | ||
| Found in Version: | 21.03.00.146 | ||
| Fixed and Released in Version: | 22.00.00.15 | ||
| Area: | Graphic User Interface | ||
| Issue #: | 956313 |
User table sections when defined using the graphic user interface are getting written in the input command file with a UNIT command within the user table definition block as shown next
START USER TABLE
TABLE 1
UNIT INCHES KIP
GENERAL
TEST1
1112.25 80 0 47 0 995062 89512 27715.6 23232.6 3809.02 525.421 550.813 -
30641.9 7257.83 8.04422e+07 80
END
Subsequently the software is incorrectly reading all the properties in meter units. This is resulting in incorrect properties being considered for the analysis and design and also incorrect display of the structure in 3D.
Workaround
Open the STAAD.Pro command file in the editor and move the UNIT INCHES KIP command in the user table definition so that it comes just before the START USER TABLE line, as shown below
UNIT INCHES KIP
START USER TABLE
TABLE 1
GENERAL
TEST1
END
Once the data is Saved from within the editor, the file should work without any problem.
The problem has been addressed in the STAAD.Pro Connect Edition version 22.00.00.15.
