How to load a default Cell Selector file automatically so its loaded for all designs
 Product:MicroStation
 Version:V8
 Environment:N\A
 Area:Cells
 Subarea:General
I want to have a Cell Selector file automatically loaded when opening a file in MicroStation
1. Create a default Cell Selector File (default.csf) as required and place this in a location required (Typically on a Server within your Organizations configuration)
Consult your Site Administrator on the best location and ask them to set the following variables at the appropriate configuration level. ( IE Organization / WorkSet )
2. Set the variable MS_CELLSELECTORDIR to point to the folder containing *.csf files
3. Set the variable MS_CELLSELECTOR with the default Cell Select File name (default.csf).
How to create a new Cell Selector csf for a new Cell Library
How to open a specific Cell Selector File with a Key-in
Other language sources
 Original Author:Carl Myhill
