What is a test in KeyLAB? A test in KeyLAB is made up of four components each one will need to be imported one at a time.
The following video shows how to get started within KeyLAB and how to import Test Definitions into the application.
The following video shows how to get started within KeyLAB and how to import Test Sheets into the application. This is repeat
The following video shows how to get started within KeyLAB and how to import AGS mapping into the application.
