Validation or Certification documents for Hydraulics and Hydrology products
Product(s):WaterGEMS, WaterCAD, HAMMER, StormCAD, SewerCAD, SewerGEMS, CivilStorm, PondPack, CulvertMaster, FlowMaster
Version(s):Various
Area: Calculations
Original Author:Jesse Dringoli, Bentley Technical Support Group
This article provides access to Validation / Certification documents for the above listed Hydraulics and Hydrology (OpenFlows) products. These documents are sometimes required in order to widely adopt software. They show that the software's hydraulic results match published or known results.
NOTE: you will need to be signed in first or the below links will not work
Certification Statement
The below document certifies that the Hydraulics and Hydrology products (listed in the header block of this article) have been validated by manual calculations or by a comparison with a previously validated computer program. The statement "validation data is on file" means that the results of our automated tests (comparing results) are stored internally for the Bentley development team to review. Please see the document further below under "Bentley Software Methodology" for more supplemental details.
NOTE: you will need to be signed in first or the below link will not work.
Certification Letter - Hydraulics and Hydrology Products
Verification Documents
CivilStorm V8i SELECTseries 2 (08.11.02.65)
The below .ZIP file contains a verification document showing how CivilStorm's results (using the Explicit numerical solver) match known results (based on EPASWMM). The data files are also included. Note that this validation was done using version 08.11.02.65 - future versions could potentially have slight changes in the numerical solver that could make the results out of date. However, these data files have been checked in later versions of CivilStorm, up to SELECTseries 4 at this time.
communities.bentley.com/.../Validation-_2D00_-CivilStorm-SS2.zip
HAMMER V8i SELECTseries 3 (08.11.03.19)
The below .ZIP file contains a verification document showing how HAMMER's results match published results. The data files are also included. Note that this validation was done using version 08.11.03.19 - future versions could potentially have slight changes in the numerical solver that could make the results out of date. However, these data files have been checked in later versions of HAMMER, up to SELECTseries 5 at this time.
If you are inquiring about QA&R for certification for the nuclear industry please note that HAMMER does not offer the same type of ‘nuclear certification’ as AutoPipe. We do have the aforementioned document and files that can be downloaded below, however, if you'd like to compare the results yourself. If you need verification of other customers in your industry that use HAMMER you should contact your Bentley account manager.
Important Notes about the Model Files
General - Note that the calculation of the initial conditions is not required with these model files, as they use custom pre-entered initial conditions (by way of setting the "Specify Initial Conditions?" Calculation option to "True", then values were populated in the respective initial conditions input fields). So, after opening the file, you only need to click the Compute button (not the Compute Initial Conditions).
Test Case 01- when utilizing the data file for test case 01, the included quadrantcurves.txt file needs to be placed in the installation folder. You may want to back up your existing quadrantcurves.txt file. Be sure to place the file in either the root of the HAMMER8 installation folder if using the 32-bit version of HAMMER (C:\Program Files (x86)\Bentley\HAMMER8), or the "x64" (C:\Program Files (x86)\Bentley\HAMMER8\x64) subfolder, if using the 64-bit version. If you are unsure of the version being used, go to Help > About HAMMER and look in the lower-left corner (64-bit will be designated here if you're using the 64-bit version).
Test Case 02 - note that the head values in the graph in the case study document are relative values of pressure head..
communities.bentley.com/.../Validation-_2D00_-HAMMER-SS3.zip
Bentley Software Development Methodology
This document describes the overall software development methodology, including development and testing.
Note: you will need to sign in first before using the below link.
Note: as of July 2017, an updated version of this document is planned to be available sometime in the near future.
FEMA Approval
See: Are OpenFlows products FEMA approved?
Note: if the pages for accepted hydraulic or hydrologic models are not working, try a web search or locate a cached copy.
