| Version(s): | through 08.11.13.140 | ||
| Area: | PowerPlatform Support | ||
| Subarea: | N/A |
An empty box or a box containing non-Promis.e or non-Substation menu items appears on screen and will not go away until the page is closed.
This box is from the secondary menu that pops up when the reset button (typically the right mouse button) is held longer than a normal click. This occurs when the Reset Pop-up Menu is set to "Press and Hold", which is typical for Promis.e and Bentley Substation.
To avoid the problem in the future increase the amount of time the right mouse button must be held for the reset menu to appear. This only affects the secondary, MicroStation reset menu, not the Promis.e/Substation right-click menu.
| Original Author: | Matt_P |
Keywords: blank, white
