| Product(s): | ProSteel | ||
| Version(s): | N/A | ||
| Area: | Modelling | ||
| Subarea: | |||
| Original Author: | Steffen Knoll, Bentley Technical Support Group | ||
Starting the stiffener connection and selecting a shape, the dialog does not appear.
The last saved settings for the stiffener dialog does not work for the selected shape.
If you have a stiffener connection in your model, select the stiffener, right click for context menu.
Open the temp folder of your ProSteel Version.
C:\Program Files\Bentley\ProStructures\V8i_S5\AutoCAD 2013\Temp\Metric
