Document Type: FAQ
Product(s): LEAP BRIDGE ENTERPRISE
Version(s): All
Original Author: Bentley Technical Support Group - VM
ANSWER:
User can update the windows from Microsoft updates .
User needs to check if he has Microsoft .NET Framework installed on computer and also the version should 4.0 or greater.
Once the .NET framework is installed the error message will go away.
