| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | Modeling | ||
| Subarea: | |||
| Date Logged & Current Version  |  Feb. 2015 09.06.01.10  | ||
In AutoPIPE, how are the hydrodynamic coefficients determined when they are set to Auto?
Open the model in AutoPIPE, select a node point and press Insert> XtraData> Hydrodynamic Data> with this dialog open press the "Help" on the dialog.
Select the Hyperlinks below for additional information on these features including what occurs when (Automatic) is used:
Mass coefficient (Cm)
Drag coefficient (Cd)
Lift coefficient (Cl)
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
