Bentley Offshore Youtube suggested playlists
Here are some suggested playlists from our Bentley Offshore Youtube channel
MAXSURF What is Maxsurf - Maximize Vessel Performance https://www.youtube.com/watch?v=sUctZaT5L2k
MAXSURF Intorduction - Maximize Vessel Performance https://www.youtube.com/watch?v=JSkygSlPgqQ
MAXSURF Promotional Video - Overview https://www.youtube.com/watch?v=HZgP1aOor-8
MAXSURF View Orientation in 3D Perspective Window https://www.youtube.com/watch?v=d37h0pwAESE
What's new in MAXSURF 23.03 https://www.youtube.com/watch?v=_tSkaYfHt7g
Modeler
MAXSURF Modeler - Quickstart Design https://www.youtube.com/watch?v=pI9X8NHfSc8
Modeling existing vessel
MAXSURF Modeler - Background Images https://www.youtube.com/watch?v=Gwhe5NVSs1I
MAXSURF Modeler - Fitting Existing Designs https://www.youtube.com/watch?v=PTeqkYdXqNU
Reverse Engineering in MAXSURF part1 https://www.youtube.com/watch?v=yaRn0XEC2d8
Reverse Engineering in MAXSURF part2 https://www.youtube.com/watch?v=MhdkgRxPVaI
Point Cloud to NURB Surface Model https://www.youtube.com/watch?v=AdyviifkbQM
MAXSURF Modeler Workflow Example - NURBS Surface Model https://www.youtube.com/watch?v=Z1pJ7uTtj9c
NURBS Surfaces
MAXSURF Modeler - Planning a Surface Layout https://www.youtube.com/watch?v=yOV9HmatIr4
MAXSURF - Graphical and Numerical Editing https://www.youtube.com/watch?v=uPsYQ3ZVu9Q
MAXSURF Modeler - Bonding Surface Edges https://www.youtube.com/watch?v=5hjFsV9hdQE
MAXSURF 22.03 - Tips and Tricks in Modeler - Surface Table https://www.youtube.com/watch?v=-bTkVkDlqIg
MAXSURF Modeler - Surface Fairing https://www.youtube.com/watch?v=eEp5WPu8M4w
MAXSURF Modeler - Surface Trimming https://www.youtube.com/watch?v=I4jBkEQYnfY
MAXSURF Modeler - Creating and Developing Plates https://www.youtube.com/watch?v=aaWjSh6tnJM
Meshes
MAXSURF Modeler - Creating a Trimesh https://www.youtube.com/watch?v=gFKCLtBlkDU
Combining both NURBS and Trimesh surfaces in a MAXSURF design file https://www.youtube.com/watch?v=yljr4dBW47M
Developable surfaces
Designing with Developable surfaces in MAXSURF https://www.youtube.com/watch?v=CdSrSSYTRxU
Working from Curves
MAXSURF Modeler - Arc Curves https://www.youtube.com/watch?v=GG73Wg2hUG4
MAXSURF Modeler - Skinning Curves around a Bilge https://www.youtube.com/watch?v=FVjnbJ1hKis
MAXSURF Modeler: Skinning Curves - Chine https://www.youtube.com/watch?v=P-ZmxTnyXDE
Multihulls
Multihull Designs in MAXSURF https://www.youtube.com/watch?v=C5iTUSZpy6o
Automation
MAXSURF Modeler - Automation Example https://www.youtube.com/watch?v=6TfV5qXr17w
Towards Hull Optioneering automation in MAXSURF https://www.youtube.com/watch?v=sFoGKuOIZHs
Accessing MAXSURF 64-bit COM Automation Interface from 32-bit Applications https://www.youtube.com/watch?v=p9cdIG-PyUA
Structural Response
Structural Response of Marine Structures in MAXSURF https://www.youtube.com/watch?v=STjQakl9r5o
MAXSURF 22.03 - Model Transfer from Modeler to Multiframe https://www.youtube.com/watch?v=3Y9wmtpUhMc
Hydrostatics in Modeler and Stability
Model requirements
MAXSURF Stability - Hull Model Analysis https://www.youtube.com/watch?v=yYP_-Iff9As
MAXSURF Stability - Checking Your Model https://www.youtube.com/watch?v=tqddhDTbbY8
Fine-tuning Hydrostatic Sections in MAXSURF Stability https://www.youtube.com/watch?v=etzrcVK1RPU
How to Deal with Longitudinal Discontinuities in the Sectional Area Curve in MAXSURF Modeler https://www.youtube.com/watch?v=u4XBi2ZSK3Q
MAXSURF Stability - Background Images https://www.youtube.com/watch?v=MEEVI0WJXxk
Analysis setup
MAXSURF Stability - Concepts and Specified Condition https://www.youtube.com/watch?v=-UbdfwOnR08
MAXSURF Stability - Modeling Rooms https://www.youtube.com/watch?v=G8xWv_kKkn8
MAXSURF Stability - Sounding Pipes https://www.youtube.com/watch?v=HiZ2D6H1le8
MAXSURF Stability - Modeling Complex Rooms https://www.youtube.com/watch?v=_fXgshUg7wc
MAXSURF Stability - Load Cases https://www.youtube.com/watch?v=thHHTDgKGeg
MAXSURF Stability - Stability Criteria https://www.youtube.com/watch?v=NHb80ljST1o
MAXSURF Stability - Waves and Grounding https://www.youtube.com/watch?v=HF1U0tFB5ow
MAXSURF Stability - Reporting https://www.youtube.com/watch?v=cZ69I-eo6Rk
Analysis modes
MAXSURF Stability - Upright Hydrostatics https://www.youtube.com/watch?v=wrkGPnLxi0g
MAXSURF Stability - Equilibrium Analysis https://www.youtube.com/watch?v=wtLzmyqOMro
MAXSURF Stability - KN Value Analysis https://www.youtube.com/watch?v=K13SIS-Y9-0
MAXSURF Stability - Large Angle Stability https://www.youtube.com/watch?v=8JKw2xFzYco
MAXSURF Stability - Floodable Length https://www.youtube.com/watch?v=GJrynIuOaQs
MAXSURF Stability - MARPOL Oil Outflow Analysis https://www.youtube.com/watch?v=n5eWspL9-k8
MAXSURF Stability - Tank Calibrations https://www.youtube.com/watch?v=ZyxzuAGnGTM
MAXSURF Stability - Batch Analysis https://www.youtube.com/watch?v=tZJLzMLlXxY
Maximum or Limiting VCG
MAXSURF Stability - Limiting KG Analysis https://www.youtube.com/watch?v=W9tvPa-D6IE
How to Calculate Maximum VCG with MAXSURF Stability https://www.youtube.com/watch?v=GIytfpmGVwQ
Troubleshoot Maximum VCG Calculations in MAXSURF Stability https://www.youtube.com/watch?v=F15zy73GTDE
Damage stability
MAXSURF Stability - Damage Setup https://www.youtube.com/watch?v=TE035xzRJBE
MAXSURF Stability - Damage Effects https://www.youtube.com/watch?v=rcGj5P5PwK0
MAXSURF Stability - Damage Criteria https://www.youtube.com/watch?v=RkVAD9w8jw8
MAXSURF Stability - Damage Limiting KG https://www.youtube.com/watch?v=7nx8wV1PLH4
Probabilistic Damage
MAXSURF Stability - Probabilistic Damage Introduction https://www.youtube.com/watch?v=JFOcCoq1b8c
MAXSURF Stability - Probabilistic Damage Global Inputs https://www.youtube.com/watch?v=gaC4VujVdW8
MAXSURF Stability - Probabilistic Damage Zones Input https://www.youtube.com/watch?v=f22jPLys_Ek
MAXSURF Stability - Probablistic Damage Criteria https://www.youtube.com/watch?v=ayMe6MemTx0
MAXSURF Stability - Probabilistic Damage Analysis Results Part 1 https://www.youtube.com/watch?v=AXEENWsK5pI
Other features in Stability
MAXSURF Stability - Analysis of Spilling Tanks https://www.youtube.com/watch?v=wtF9k7BycsQ
Resistance and Sailing performance
MAXSURF Resistance - Introduction https://www.youtube.com/watch?v=fqytfgOeZOk
MAXSURF VPP - Introduction https://www.youtube.com/watch?v=L07_WHdRffU
MAXSURF Resistance - Measuring Surfaces https://www.youtube.com/watch?v=RpJm-R88AV4
MAXSURF Resistance - Analysis https://www.youtube.com/watch?v=Mshii2tPqUo
MAXSURF Resistance - Slender Body Method https://www.youtube.com/watch?v=riUlkddIFQE
MAXSURF Resistance - Calculating Wake https://www.youtube.com/watch?v=cKQxD9pSl28
Ship Motions
MAXSURF Motions - Prediction Using Seakeeper: Intro https://www.youtube.com/watch?v=xrxOMt8m_cc
MAXSURF Motions - Predictions Using Seakeeper: Inputs https://www.youtube.com/watch?v=r6aHtr3QLZg
MAXSURF Motions - Prediction Using Seakeeper: Setup https://www.youtube.com/watch?v=uaciPQ64hFk
MAXSURF Motions - Prediction Using Seakeeper: Results https://www.youtube.com/watch?v=6OzaMLz4Gh8
MAXSURF Motions - Prediction Using Seakeeper: Visualization https://www.youtube.com/watch?v=BIXWcbL8TQM
Multiframe structural analysis
Introduction
MAXSURF Multiframe - Geometry Setup https://www.youtube.com/watch?v=Cyz0Y9MqZw0
MAXSURF Multiframe - Sketching Structures https://www.youtube.com/watch?v=0Mnk5agT0Wk
MAXSURF Multiframe - Generating Structures https://www.youtube.com/watch?v=Z9LRPy15bQs
MAXSURF Multiframe - Creating Structural Geometry https://www.youtube.com/watch?v=xCBsFO03R5o
MAXSURF Multiframe - Graphical Modification https://www.youtube.com/watch?v=4p7_v935LfU
MAXSURF Multiframe - Numerical Modification https://www.youtube.com/watch?v=1VTFIsXw9QQ
MAXSURF Multiframe - Creating Curved Geometry https://www.youtube.com/watch?v=Qch3iM3gC4E
MAXSURF Multiframe - Importing Geometry https://www.youtube.com/watch?v=cj8iKEdDugM
MAXSURF Multiframe - Restraints https://www.youtube.com/watch?v=qz7zpbf48jg
MAXSURF Multiframe - Sections and Materials https://www.youtube.com/watch?v=BNGC2xelMFw
MAXSURF Multiframe - Applying Properties https://www.youtube.com/watch?v=G4uZRRCN6kQ
MAXSURF Multiframe - Member Orientation https://www.youtube.com/watch?v=bGCbdzWOEv8
MAXSURF Multiframe - Member Offsets https://www.youtube.com/watch?v=-YLyy2UBb78
MAXSURF Multiframe - Releases and End Springs https://www.youtube.com/watch?v=bn0BscFZZcI
MAXSURF Multiframe - Master Slave https://www.youtube.com/watch?v=Hd0-lU40N2w
MAXSURF Multiframe - Automation https://www.youtube.com/watch?v=Js3yvTccJjM
Loads
MAXSURF Multiframe - Load Case Management https://www.youtube.com/watch?v=EH14fAAk0Y0
MAXSURF Multiframe - Applying Loads https://www.youtube.com/watch?v=tXjXJw3W3ks
MAXSURF Multiframe - Member Loads https://www.youtube.com/watch?v=ptoNRc37sF8
MAXSURF Multiframe - Joint Loads https://www.youtube.com/watch?v=DkLkBE-V31Q
MAXSURF Multiframe - Panel Loads https://www.youtube.com/watch?v=3U9N_c27KL8
MAXSURF Multiframe - Wind Loads https://www.youtube.com/watch?v=7VzSdpEnCPE
MAXSURF Multiframe - Thermal Loads https://www.youtube.com/watch?v=yI--Xs_My_4
MAXSURF Multiframe - Patch Loads https://www.youtube.com/watch?v=7rvLTI1h6pQ
MAXSURF Multiframe - Hydrostatic Loads https://www.youtube.com/watch?v=LQlcjpapT9Q
MAXSURF Multiframe - Sea Motion Loads https://www.youtube.com/watch?v=9ZL0IN6UyLs
Analysis and Results
MAXSURF Multiframe - Simple Beam Analysis https://www.youtube.com/watch?v=RRTmLPzGThw
MAXSURF Multiframe - Continuous Beam Analysis https://www.youtube.com/watch?v=nQZf9kw5Mh0
MAXSURF Multiframe - 2D Truss Analysis https://www.youtube.com/watch?v=voxGK8BZBj8
MAXSURF Multiframe - Analyzing Results https://www.youtube.com/watch?v=NpWAZTRdMAo
Further help
BentleySystems StudentCenter
https://www.youtube.com/channel/UCHBuZrXlQImsHnXUiGTFIvQ
Bentley Offshore Analysis
https://www.youtube.com/channel/UCW3O3jM48Ugy7mSB9duUUqw
