| Version(s): | All | ||
| Subarea: | Specifications | ||
I am trying to model a beam connecting to the flange of a column instead of at the center. How is this modeled?
You have to use a facility called member offsets. You "offset" the face of the beam by a distance equal to half the depth of the column cross-section. An example of this can be found in Example # 7 in the STAADPro Examples Manual.
