| Version(s): | 08.09.00.92 | ||
| Area: | Dimensions | ||
| Subarea: | Dim Styles | ||
How to preview the changes that are made to the dimension settings dynamically.
Under the Dimension Styles, make sure that the Toggle Preview button is selected or go to View > Preview. This will toggle the dynamic preview on or off for the dimension styles.
