| Version(s): | 08.05.02.35 | ||
| Area: | Custom Linestyles | ||
| Subarea: | N\A | ||
MDL Abort in DRAGLIST.MC at line 2047.
When trying to load linestyle manager tool, getting error: MDL Abort in DRAGLIST.MC AT LINE 2047
Possible solutions:
-Installed Axiom products could be causing a conflict
Solution: Check to see if Axiom products are installed. If so load MicroStation without the Axiom product(s) running.
-The draglist.msl file could be bad, or an incompatible version.
1. Close MicroStation
2. Acquire a version of this file from a installation where the Line Style Manage function works
3. In Windows Explorer, Browse to the location of the draglist.msl file within the installation where the Linestyle Manage function does not work
4. Replace the bad draglist.msl file with the good one
Note:
The default location of draglist.msl is...\Bentley\Program\MicroStation\mdlsys\asneeded\
