| Version(s): | All | ||
| Area: | Steel Design | ||
| Subarea: | Verifications | ||
| Original Author: | Jason Coleman Bentley Technical Support Group | ||
The following are a set of documents that cross compare the results produced from a STAAD.Pro design of steel members to the new Indian IS 800:2007 design code with equivalent hand calculations. The STAAD.Pro files are included in the installation of STAAD.Pro V8i Build 05 in the STAAD/EXAMP/IND folder.
