| Version(s): | 08.11.09.xxx | ||
| Area: | Interchange | ||
| Subarea: | General | ||
| Original Author: | Bentley Technical Support | ||
When I save a V8 file to V7 file using Level Mapping in the Save As V7 options, some of the levels are not being remapped to the resultant V7 file.
In the V8 file open the Level Manager dialog and right click on one of the column headings such as ' Name ' then check the option to display the ' Number ' column if not already visible.
If there is no ' Number ' assigned against a level that does not get remapped, add one before saving to V7 format.
It is also possible to use the capability switch below to automatically generate level numbers.
_USTN_CAPABILITY <(><<)> +CAPABILITY_LEVELS_USE_AUTO_GENERATED_NUMBERS
Resources
Auto Generate level numbers
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0113692
Save as V7 Process
https://communities.bentley.com/products/microstation/w/microstation__wiki/15001.remap-level-names-to-level-number-for-v8-to-v7.aspx
