Applies To | |
Product(s): | AutoPIPE |
Version(s): | ALL; |
Area: | Readme |
Date Logged & Current Version | Jan 2019 12.00.00.14 |
The following outline identifies new features and enhancements in the AutoPIPE CONNECT Edition version 12.00.00.14
1 The Version 6.1 Point Data Listing, Extended Component Data Listing, Flange Analysis Report, and Thermal Transient Analysis Report are not available in the SQLite DB format. This feature will be made available in a future release.
Technology Previews - Provide users preliminary access to features currently in development but not yet ready for production. These features are provided at no additional charge to promote awareness of a feature or technology to be deployed in a future release. Users are encouraged to provide feedback and suggestions. Now all Technology previews are available in the application. These commands have '[Technology Preview]' displayed in the tool tip.
More detailed installation information can be found in the AutoPIPE Quick Start Guide.
Product | AutoPIPE |
Version | v.12.00.00.14 |
Language | English |
CD drive or access to the Internet required for product installation. The minimum system configuration for installation:
Operating System | Microsoft Windows 7 Professional or higher (with Service Pack 1) Microsoft Windows 8 Professional or higher Microsoft Windows 8.1 Professional or higher (with KB2919355 Update) Microsoft Windows 10 Professional or higher 32 or 64 bit OS |
.NET Framework |
3.5 SP1 |
When installing the product through the installer program, the required components will be installed automatically. The contents of the Desktop Prerequisite Pack include:
The minimum recommended workstation profile for running AutoPIPE is:
Processor | Intel Pentium IV or higher. |
Memory | 1 GB recommended. More memory almost always improves performance, particularly when working with larger models. |
Hard Disk | 1 GB free disk space (not including Restore Point space requirements). |
Video Graphics Card | Any industry-standard video card which supports OpenGL 3D graphics. |
ProjectWise |
ProjectWise Server 10.00.03.140 with ProjectWise Explorer 10.00.03.140 ProjectWise Server 10.0.1.67 with ProjectWise Explorer 10.0.1.67 ProjectWise Server 10.0.0 with ProjectWise Explorer 10.0.0.11 or higher ProjectWise Server 8.11.7 with ProjectWise Explorer 8.11.7.133 or higher ProjectWise Server 8.11.9 with ProjectWise Explorer 8.11.9 ProjectWise Server 8.11.11 with ProjectWise Explorer 8.11.11. |
OpenPlant Isometrics Manager V8i |
08.11.11.285 V8i |
PDF Reader | Adobe® Acrobat Reader 7.0 or greater |
QA Users:
Only model analysis performed on a AutoPIPE version installed from the QA CD sent by the QA manager are concerted to be certified under the QA Procedures. Any model analysis performed on a AutoPIPE version installed from a downloaded file should be considered invalid and must be re-run on a certified installation of the program.
See Link here for valid installation procedure.
Non-QA Users:
See the AutoPIPE Quick Start Guide (..\Documents\Quickstart_AutoPIPE.pdf) for more information on downloading and installing AutoPIPE.
To complete the licensing process, you must have the appropriate roles assigned by your Site Administrator. If you have not been assigned these roles, you will need to obtain the name of your Site Administrator by submitting a Service Request at http://apps.bentley.com/srmanager/ProductSupport.
If you are experiencing problems logging into your Bentley account, please contact bentley at 1-800-BENTLEY (1-800-236-8539). Outside the United States +1 610-458-5000.
Network Considerations - Network drives are only supported for data files.
- AutoPIPE software must be installed on a local client workstation.
- AutoPIPE data files (*.DAT) must have full read/write access to be opened and edited.
AutoPIPE Standard, AutoPIPE Advanced, AutoPIPE Nuclear, and add-ons are installed from one executable.
NOTE: For further information on translators, please refer to their respective readme files.
Program Help: Detailed feature information may be accessed directly from the calling application by selecting the Help command, or by pressing the Help button from any of the application dialogs. Be sure to explore the program Help for answers to your questions. A set of supplemental How To, Tutorial, and Reference Information documents in PDF format are provided in the Supplemental Documentation folder (Bentley AutoPIPE > Supplemental Information) of the main Program Help file (autopipe.chm).
Tutorials: Documentation for AutoPIPE applications is provided online in the Adobe.pdf format. These files are accessible from the Help Menu. All documents can be browsed, searched, or printed with the Adobe Acrobat Reader. Information and how to download a FREE copy of the Adobe Acrobat Reader can be obtained from http://www.adobe.com/.
It is highly recommended that you obtain the latest version of the Adobe Acrobat Reader..
This sections contains the list of piping codes, code editions supported and AutoPIPE license edition (Standard, Advanced or Nuclear) for which these items are supported.
Piping Code | Description | Editions |
B31.1 Power | Power Piping | 1967, 1986, 1992, 2004, 2005 Addenda, 2007, 2009 Addenda, 2010, 2012, 2014, 2016 |
B31.3 Process Piping | Process Piping | 2004, 2006, 2008, 2010, 2012, 2014, 2016 |
B31.4 Liquid Trans. | Liquid Transportation Systems for Hydrocarbons, Liquid Petroleum Gas, Anhydrous Ammonia and Alcohols | 2006, 2009, 2012, 2016 |
B31.8 Gas Trans. & Dist. | Gas Transmission and Distribution Piping Systems | 2003, 2007, 2010, 2012, 2014, 2016 |
EN 13480 | European Piping Code for Metallic Industrial Piping | 2002, 2010 Addenda, 2012 |
General | General Piping Code | Not Required |
ASME B31J |
Stress intensification factors, flexibility factors, and sustained stress factors used in B31 piping analysis | 2017 |
AutoPIPE Advanced includes all codes available in AutoPIPE Standard, as well as the following codes.
CSA-Z662 | Canadian Standards Association, Oil and Gas Pipeline System | 1999, 2007, 2011, 2015 |
CSA-Z662 Offshore | Canadian Standards Association, Offshore Steel Pipelines | 1999, 2007, 2011, 2015 |
BS 806 | Design and Construction of Ferrous Piping Installations for and in Connection with Land Boilers | 1993 |
BS 7159 | Design and Construction of Glass Reinforced Plastics (GRP) Piping Systems for Individual Plants or Sites | 1989 |
SPC-2 | Swedish Piping Code, Method 2 | 1978 |
TBK5-6 | General Rules for Piping, The Norwegian Pressure Vessel Committee | 1990 |
STOOMWEZEN | Dutch Piping Rule D1101 of the Rules for Pressure Vessels | 1978 |
DNV Offshore | Det Norske Veritas, Rules for Submarine Pipelines | 1981, 2012 |
MITI 501 3-1980 | MITI 501 Class III Piping Code | 1980 |
KHK | KHK E 012 Piping Code, Seismic Level 1 or 2 (Seismic Level 2 requires a KHK 2 Add-On license) | 2006 |
RCC-M | French Piping Code for Power Industry | 1985 |
SNCT | French Piping Code for Process Industry | 1985 |
SNIP Russian 2.05.06-85 Oil & Gas | Russian SNIP piping code for oil and gas | 1997 |
ISO 14692 | Petroleum and Natural Gas Industries - Glass Reinforced Plastics (GRP) Piping | 2002+2005 addenda |
B31.4 Offshore | Offshore Liquid Piping Systems | 2006, 2009, 2012, 2016 |
B31.8 Offshore | Offshore Gas Transmission | 2003, 2007, 2010, 2012, 2014, 2016 |
AutoPIPE Nuclear includes all codes available in AutoPIPE Standard and AutoPIPE Advanced, as well as the following codes.
ASME NB Nuclear | Boiler and Pressure Vessel Code, Rules for Construction of Nuclear Power Plant Components; Division 1, Subsection NC, Class 1 Components | 1972 W Addenda, 1975 W Addenda, 1977, 1982 W Addenda, 1983 W Addenda, 1988 Addenda, 1989, 1989 Addenda, 1993 Addenda, 1994 Addenda, 1997 Addenda, 1998, 2001, 2004, 2007, 2008 Addenda, 2010, 2011 Addenda, 2013, 2015, 2017 |
ASME NC Nuclear | Boiler and Pressure Vessel Code, Rules for Construction of Nuclear Power Plant Components; Division 1, Subsection NC, Class 2 Components | 1972 W Addenda, 1975 W Addenda, 1977, 1980 S Addenda, 1983 W Addenda, 1988 Addenda, 1989, 1989 Addenda, 1993 Addenda, 1994 Addenda, 1997 Addenda, 1998, 2001, 2003 Addenda, 2004, 2007, 2008 Addenda, 2010, 2011 Addenda, 2013, 2015, 2017 |
ASME ND Nuclear | Boiler and Pressure Vessel Code, Rules for Construction of Nuclear Power Plant Components; Division 1, Subsection ND, Class 3 Components | 1972 W Addenda, 1975 W Addenda, 1977, 1980 S Addenda, 1983 W Addenda, 1988 Addenda, 1989, 1989 Addenda, 1993 Addenda, 1994 Addenda, 1997 Addenda, 1998, 2001, 2003 Addenda, 2004, 2007, 2008 Addenda, 2010, 2011 Addenda, 2013, 2015, 2017 |
JSME PPC Nuclear | JSME S NC1: Rules on Design and Construction for Nuclear Power Plants, Class 2 Piping | 2005, 2008 |
CONNECT licensing is Bentley's new licensing model, providing enhanced security and optimized value for your Bentley Subscriptions. It is integrated with Bentley's Identity Management System (IMS) and the Bentley CONNECT technology platform to allow near real-time reporting of usage, improved alert messaging to users and increased administrative capabilities to license administrators in your organization. It will not only give you more options to monitor and manage usage but also provide new, advanced licensing features that will enhance digital workflows.
With CONNECT Licensing, all users must be registered with Bentley's Identity Management System (IMS) and sign in to the CONNECTION Client to access Bentley applications. Product activation will now occur through user sign-in to the CONNECTION Client with a valid IMS ID associated with their account. User sign-in will replace traditional activation keys, offering enhanced security as administrators will be able to control which users have access to Bentley software. License entitlements are granted and maintained through CONNECT Licensing's Entitlement Management Service. By signing into the CONNECTION Client users can also find their organization's projects, download software updates, receive relevant notifications, and track their usage.
CONNECT Licensing features the new license alerts notifications that can be set by an organization's license administrators to let the users know when they reach a set usage threshold. These notifications will alert the users that if they continue to use the product, a term license may be issued. The user in such a situation has the choice to quit the application before a license is used or acknowledge that a term license may be generated and proceed with starting the application, based on what settings the administrator chooses.
The following outline identifies all major errors fixed in Release of AutoPIPE v11.3.0.
The following outline identifies all major errors fixed in Release of AutoPIPE v12.0.
Some pipe materials are using incorrect values of thermal expansion and/or modulus of elasticity. Using these pipe materials may result in incorrect calculated stress. The calculated stress values may be lower than the actual stress values leading to un-conservative results.
Pipe Material ASME Composition Thermal Expansion Modulus of Elasticity
SA666-XM11 21Cr-6Ni-9Mn Correct* Incorrect
SA691-0.5CR 1/2Cr-1/2Mo Correct Incorrect
SA691-1CR 1Cr-1/2Mo Correct Incorrect
SA691-1.25CR 1.1/4Cr-1/2Mo-Si Correct Incorrect
SA691-5CR 5Cr-1/2Mo Incorrect Incorrect *Thermal expansion values are taken from Group 15Cr&17Cr of table TE-1 of ASME BPVC II-D
SA182-F22 was deleted for ASME BPVC II-D 1998 and later editions. However, AutoPIPE's ASME2000 and later material libraries continued to provide SA182-F22. Also, allowable stress, yield strength and design stress intensity values of SA182-F22 in AutoPIPE's ASME2000 and later material libraries were different from those provided in ASME BPVC II-D 1992 edition. Using the allowable values from AutoPIPE's ASME2000 material library for SA182-F22 may result in higher calculated allowable stress value as compared to allowable stress values provided by AutoPIPE's ASME1992 material library.
Soil points along the bend uses pipe SIF values while it should use bend SIF values. For ASME codes this happens in all cases except when a frame is inserted at near point of the bend. For non-ASME code this happens only when a frame is inserted at near point of the bend.
For ASME 2010 and later, "Young modulus" for following specification materials is picked from a wrong standard material: Specifications SA243-WPB, SA243-WPC, SA350-LF2, SA36, SA420-WPL6, SA515-70, SA516-60, SA516-70, SA53-A, SA541-1A, SA672-B60, SA672-B65, SA672-B70. The difference between the values is less than 2% with the maximum difference being only 1.47%.
B31.4 "2016" and B31.8 "2012 or later" material libraries are not up to date with the applicable code edition changes.
Thermal expansion, Modulus of elasticity and Design stress intensity values for some pipe materials may not be correct
For ASME 1992 & 1986: 1. Modulus values of Group-B & Group-C are incorrect 2. Thermal Expansion values for AU-Type316 are incorrect
For ASME 2004 to 2015 1. SA430-FP316N design stress intensity values are incorrect.
For ASME 2013 & 2015 1. SA508-3-1 using incorrect values of thermal expansion and modulus
TRADEMARK NOTICE
Bentley, the "B" logo, AutoPIPE, MicroStation, ProjectWise, SELECT, and MDL are either registered or unregistered trademarks or service marks of Bentley Systems, Incorporated, or one of its direct or indirect wholly-owned subsidiaries. Other brands and product names are trademarks of their respective owners.
COPYRIGHT NOTICE
© 2018, Bentley Systems, Incorporated. All Rights Reserved.
Including software, file formats, and audiovisual displays; may only be used pursuant to applicable software license agreement; contains confidential and proprietary information of Bentley Systems, Incorporated and/or third parties which is protected by copyright and trade secret law and may not be provided or otherwise made available without proper authorization.
Complete copyright information can be found in the product by choosing Help > About.
For reference, a copy of the End User License Agreement named "EULA.pdf" is included in the "AutoPIPE V8i SELECTseries5" folder of the product installation. By default, this location is "C:\Bentley\AutoPIPE V8i SELECTseries5".
Corporate HeadquartersBentley Systems, Incorporated |
International HeadquartersBentley Systems Europe B.V. |
Asia HeadquartersBentley Engineering Software Systems |
AutoPIPE CONNECT Release Notes (10.00.xx.xx - higher)
How do I download, install, and license AutoPIPE?
