| Version: | V8i, CONNECT | ||
| Area: | DWG | ||
| Subarea: | Open |
How to disable the creation of backup files (.bak) when a DWG file is opened in MicroStation.
When MS_NO_DWG_BACKUP is set to 1 the backup files will NOT be created when a DWG or DXF file is opened or editted.
