| Defect Number | Description |
| 744331 | Resolved issue with mesh element's indices that are incorrectly created in DWG |
| 709039 | Resolved issue with converting specific .LAZ does not maintain Coordinate System |
| 567368 | Resolved issue when converting specific E57 to .POD |  |
| 750329 | Fixed issue with DWG Text from Section Block not Aligning correctly |
| 718050 | Resolved crash while importing specific keyin based text file |
| 717310 | Fixed issue with text using key-in strings for Text Attributes that would cause specific crash in MicroStation CONNECT Edition |
| 747824 | Fixed issue with Editing the Thermatic Height Display Style with ESC closes dialog and MicroStation becomes unresponsive/td> |
| 746738 | Resolved specific issue with fence clip and reference with offset/td> |
| 727233 | Resolved issue with compile after including Contraint3dElementAPI.h |
| 749828 | Fixed issue with creating polygons with sides not orthogonal between them |
| 752445 | Resolved issue with creating a new material in an empty file where the palette name cannot be changed. |
| 775584 | Fixed issue with element section using crossing will select masked reference elements. |
| 771306 | Fixed issue with PDF that doe not display a correct size when the scale is other than 1 |
| 779214 | Fixed issue with DWG with annotation scale applied to the viewport displays differently in MicroStation than in AutoCAD |
| 773653 | Decreased the time to display properties dialog when a cell is selected in the cel library dialog with the properties dialog opened |
| 764291 | Fixed Cubic mapping not being correct in render on mesh |
| 744567 | Resolved issue when selecting elements in master, elements in clipped reference are selected as well |
| 773320 | Added missing DSpiral2dBase.h file in SDK |
| 723706 | Resolved issue with Sheet Border when created in 2D Design model does not remain associated with sheet in specific file |
| 752683 | Fixed issue when copying a clipped self reference file crashes MicroStation |
| 746831 | Resolved MicroStation crash after applying display rules with patterns and selecting and deselecting elements |
| 784862 | Fixed Vertical Reprojection incorrect when converting from Geoid to Geoid with different datums. |
| 785432 | Fixed Microstation crashs when selecting favourites when place text field |
| 765447 | Resolved issue with Configuration Variables dialog displays duplicate entries for _USTN_WORKSETSDGNWSROOT |
| 765448 | Resolved issue with Configuration Variables dialog displays duplicate entries for _USTN_WORKSETDGNWS |
| 730520 | Decreased time to apply variarations of Parametric cell |
| 691510 | Resolved issue with specific external material table will not be transfered to a copied model. |
| 372770 | Fixed Place Note tool the text line weight is 0 regardless of the active line weight or the text style. |
| 762837 | Resolved issue with specific MicroStation crash on startup with custom VBA |
| 792843 | Resolved issue with Raster Line Styles are not being honored when enabling on/off the Line Style in the View Attribute dialog. |
| 737438 | Fixed MicroStation crash while viewing the specific attached SP3D i-Model |
| 786529 | Fixed issue with specific DWG Text for Cell blocks not aligned correctly |
| 747381 | Fixed issue with Reference using saved views are shifted on file open with specific file. |
| 676990 | Resolved issue with Text node not appearing after changing properties. |
| 780401 | Checking if a shape element is Planar in VBA gives inconsistent results |
| 759751 | Resolved VBA issue withsAssigning new TextStyle to Textelement in TextNode raises runtime error |
| 744132 | Fixed VBA attachment object invalid after executing an Undo of previous attachment move |
| 694656 | Fixed issue with light preview wont reflect color change immediately required to regenerate preview |
| 710610 | Resolved issue when opening a specific file with a bitmap image causes crash |
| 765449 | Fixed issue with DGNWS is not being written to when relocated using _USTN_WORKSETDGNWS |
| 746438 | Fixed issue whith DWG Referenced Note Rotates Text When Using "Use Annotative Scale" |
| 755156 | Resolved issue with FBX files do not display texture |
| 797532 | Resolved issue with specific file where Bing Maps displays at incorrect position |
| 797279 | Rationalize BeTA2010 German GCS |
| 706075 | Resolved issue with specific DWG File causing hang on open |
| 807476 | Fixed issue with logical value displays as Master in Level Manager with empty levels from DGNLIB |
