| Version(s): | 08.11.09.459 | ||
| Area: | Interchange | ||
| Subarea: | General |
NWD file format does not open in MicroStation.
NWD file format is not supported in MicroStation. Please install FBX converter which allows to convert NWD into FBX format. FBX file format can be then open in MicroStation. FBX Converter program is available for download on following website:
FBX Converter: Windows installation (autodesk.com)
Alternatively, there is a workflow in more recent versions of this Autodesk Navisworks product to export to the FBX file format.
To Export an FBX File | Navisworks Products 2019 | Autodesk Knowledge Network
Compatibility between MicroStation and Autodesk Navisworks
| Original Author: | Andrea Figurova |
