In OpenBridge Modeler CONNECT Edition when user hit the Add Bridge tool button he will be selecting also one Bridge Type in the drop-down list, as shown in the screenshot below. All further definitions will be relate to this very important selection when adding a new bridge to the OpenBridge Modeler design. Depending on the Bridge Type selected all other commands will change, leading to a much faster project definition. The program settings will gray-out/shield or show-up additional options accordingly. Therefore, it is important to clarify:
