| Product(s): | InRoads |
| Version(s): | 08.11.07.615 |
| Area: | Survey |
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group |
Question:
How can you convert the units of Survey Data?
Answer:
For survey data, units are set in Tools > Survey Options. This is also the location where previously imported survey data can be converted.
For surface (DTM) data, use the command Surface > Edit Surface > Transform Surface. In this command, you save the converted surface data in new surface.
