| Product(s): | TMA | ||
| Version(s): | 5.4 | ||
| Area: | TMA Inspection | ||
| Subarea: | N/A | ||
When scheduling inspections it only assigns to 1 inspector but I have 3 inspectors.
Replication Steps: User goes into the scheduler and run this for the current date. When checking the output only 1 inspector has inspections assigned to them.
Inspections are assigned to inspectors and this is dependent on who had been declared in the Annual Inspection Profile form. To check this go to TMA5110 and check that the ruleset tab has inspectors in the list and that they are ticked as available. If they are then make sure that they are correct against all the current year undertakers. If you only add the ruleset to 1 undertaker then it will only schedule the inspections for the declared inspectors against that utility.
