Applies To | |||
Product(s): | Bentley GEOPAK Civil Engineering Suite | ||
Version(s): | 08.11.07.615 | ||
Environment: | N/A | ||
Area: | Survey | ||
Subarea: | gpk import points | ||
Original Author: | Nico Roman, Bentley Technical Support Group | ||
We are working with exporting points from the Cyclone software in PNEZ format to import into Geopak Datasets. We are encountering some problems in inserting the points into the GPK. Do you know how many points the Datasets will support when creating from an ASCII file?
The limit is not in the datasets, the limit is in the gpk file, the max limit size of the gpk is 32 mb….. can be easely reached with about 70000 pts more or less.
