| Application | PLAXIS 2D |
| Issue status | ✔ Solved |
| First Affected Version | PLAXIS 2D 2018.00 |
| Found in Version | PLAXIS 2D 2018.00 |
| Fixed and Released in Version | PLAXIS 2D 2018.01 |
| Issue # | SW-27263 |
| Date created | 30 May 2018 |
| Date modified | 22 November 2018 |
In PLAXIS Input and PLAXIS Output you can access the Command reference under the Help menu. In order to query information on a command or an object, a search field is provided at the top-right side of the window.
In the PLAXIS 2D 2018.00 version, the search field is giving an error saying:
Couldn’t load index for ‘Input commands reference’ located at ‘../input_commands’
Error message in the browser
The results of the search are shown only if you press OK on this popup error window.
The error appears due to a typo in the import command for the Input program and a JavaScript file that is provided in the Plaxis installation.
This issue is resolved in PLAXIS 2D 2018.01.
If you encounter this problem, the following steps need to be taken to fix the problem :
The process requires Administrative rights to paste files into the Plaxis folder. In that case, contact you IT department to assist you in resolving this.
