| Version(s): | CONNECT Update 5 | ||
| Area: | FAQ | ||
| Subarea: | N\A |
This is the list of the resolved issues for MicroStation CONNECT Edition Update 5, 10.05.00.40
See HTML Table below
| Defect Number | Description |
| 692278 | Resolved issue with specific Luxology preset material not correctly working. |
| 677560 | Resolved crash when you have Bing Map attached and have a mesh and change View Attribute from Wireframe to Smooth. |
| 675300 | Fixed issue with configuration variable MS_DWG_VERSION = 2013 does not set the save as DWG option are defaulted to 2013. |
| 668493 | Resolved issue with an item type property that could not be removed if importing the generated xml file. |
| 662412 | Fixed issue with user unable to remove a tab under the custom workflow. |
| 658882 | Resolved issue with solid having a Modified Vertex that gives incorrect result when United with other solids keeping 'Merge Parametric Solids' option set to ON. |
| 658875 | Resolved issue with not being able to Unite Solids after having Modified Edge with other solids keeping 'Merge Parametric Solids' option set to ON. |
| 650252 | Fixed issue with Dot cell terminator on a note is not scaling correctly. |
| 646764 | Resolved issue with specific file when publishing an i-model results a crash. |
| 645916 | Resolved issue with 'Synchronize/Follow/Capture Google Earth View' tools are not working with Google Earth PRO version. |
| 643187 | Resolved issue with a specific .dwg file where some element colors display incorrectly. |
| 641653 | Fixed issue with Auto-Center does not work well in X-Axis when page size length is larger than 1500 mm. |
| 636980 | Width of text node masking in DWG is displayed larger in AutoCAD than in MicroStation. |
| 636327 | Fixed issue with converting from DGN to DWG and line style setting Width changes in specific file. |
| 633337 | Resolved issue with using Chinese characters in Tags value not displaying on screen correctly. |
| 632088 | Resolved issue with associated text to rotate with elements. |
| 620204 | Resolved issue with Label coordinate tool does not honor the accuracy setting. |
| 617651 | Resolved Microstation crash on selecting task navigation custom menu from Ribbon > Task Navigation > dropdown list. |
| 614268 | Fixed issue with keyin: "REFERENCE SET ATTACHMETHOD=geoReprojected reference Bing Map is not automatically reprojected. |
| 614242 | Resolved issue with Reproject Bing Map into the another model causes crash in specific file. |
| 566468 | Resolved issue with unable to identify upper right of paper menu when working with INTUOS4 along the lens cursor device. |
| 555815 | Fixed issue with Change Text Style casuing color changes even when it is not defined in Text Style. |
| 469770 | Resolved issue with MicroStation CONNECT crashes converting DWG to i model in specific file. |
| 446232 | Resolved issue with specific Dimension style does not update from dgn library. |
| 439018 | Fixed issue with MicroStation hanging when Bing Maps reprojected to "EPSG:102123" GeoCS. |
| 369008 | Resolved issue with Unicode tag values are not retained when opening file in MicroStation V8i and MicroStation CONNECT Edition. |
| 671904 | Fixed issue with Titleblocks not being honored in Print Organizer with workspaces or worksets. |
| 619962 | Included option to disable keyin browser when "enter" key is invoked. |
| Original Author: | Maria Munoz |
