How to turn Steel Connections
Product(s):ProStructures & ProSteel
Version(s):CONNECT Edition (10.XX.00.XX)
Environment:N/A
Area:Steel Modelling
Subarea:Steel Connections
Original Author:Alistair Lobo, Bentley Product Advantage Group
An end plate connection is placed rotated by 90 degrees, contrary to required. How can this connection then be turned ?
The connecting profile is a rectangular hollow section. This plays a role with connections and here the profile has been inserted rotated by 90 degrees.
Now, in the PS Properties, if the profile is again rotated using the -90 or +90 degree button, the connection also rotates.
In this manner, one can control the orientation of the connection by selecting the position / rotation of the connecting member.
