| Issue status | ✔ Solved |
| First Affected Version | PLAXIS 2D AE.00 PLAXIS 3D 2012.00 |
| Found in Version | PLAXIS 2D AE.00 PLAXIS 3D 2012.00 |
| Fixed and Released in Version | Solved in a recent version |
| Issue # | 18459 |
| Date created | 15 October 2014 |
Structural user features (plates, embedded piles, anchors, etc.) in PLAXIS are automatically given a name in the Input program, such that that the PLAXIS programs can easily refer to these structural user features in the Model explorer, Selection explorer and the Command line.
This Model explorer from the Input program is also shown in the Output program at the left side of the model to easily inspect the model by hiding and/or showing items. However, the internal structure of the Output program uses a different numbering compared to the Input program’s numbering to display the model and the results: the Finite Element numbering from the generated mesh. This can be seen in Output’s model explorer when expanding for instance one plate element:
Figure 1. Model explorer with Plate_1_1 as shown in Input (left) and Output (right)
Here Plate_1 and Plate_1_1 can be recognized from Input’s Model Explorer. When expanding Plate_1_1 in Output, Output’s Model explorer will show the plate element numbers from the Finite Element mesh of which this Plate_1_1 consists. In the above example, you may notice a Plate 1 element number , which can be easily confused with the Plate_1 from the Input program (see left side of Figure 1).
This difference in naming of plate elements in Input and Output can be confusing sometimes:
Figure 2. Element number displayed in Output status bar when hovering the mouse over a plate element
Figure 3. Table of plate results. First column shows Plate 1-2 in which plate chain 1, plate element 2 is meant
This confusion may occur for any structural element, for example beams, plates, geogrids, embedded piles, embedded pile rows, interfaces, node to node anchors, fixed end anchors and wells.
This issue is now solved since PLAXIS 2D 2015.00 and PLAXIS 3D AE.00. Now when viewing the table, the element number is explicitly mentioned as Element. while also the structural element name (from the Input model tree) is shown.
For PLAXIS 2D AE (and earlier) and PLAXIS 3D 2013 (and earlier), be careful which element you are reviewing in the table, or which element you are hovering over with your mouse pointer. Please check the assigned materials and the coordinates to make sure you select the correct element or inspect the correct structural element in the tables.
