| Version: | V8i, CONNECT Edition | ||
| Area: | Graphics Display | ||
| Subarea: | General |
Ultra-high resolution displays, resolutions above Full HD (1080p) such as 4K, have risen in availability and affordability. New laptops are being manufactured with these displays as well. Due to the increased resolution certain elements of the User Interface appear smaller to offset this a feature within Windows is used. This is known as Display Scaling.
The goal of this feature is to keep the sharpness and quality of the high resolution display but enlarge elements of the interface. The drawback of this is that an application must be built with this in consideration leading to issues with scaling older Windows Applications.
Common issues are Text is to large, icons remaining small.
Windows 10 offers improved handling and more flexibility regarding text scaling and multiple monitor resolutions, particularly from the Creators Update onwards. Various combinations can be chosen from the Windows 10 Display Settings dialog:
Disable display scaling for older versions of MicroStation by:
Right click on the MicroStation shortcut and select "Properties"
Go to the "Compatibility" tab and enable the “Disable display scaling on high DPI settings” option
In Windows 10 this dialog has changed slightly, if you would prefer to make MicroStation ignore Windows display scaling tick the "Override" box and select "Application".:
Picking the option: "Disable Fullscreen Optimizations" are also known to have helped some users that had issues with the crosshair not properly displaying.
Set MicroStation to use the delivered large icons:
Increase the Dialog Font:
Lower the resolution of the Display
Through windows adjust the resolution so items become larger. This could lead to lower picture quality and should only be used as a last resort as this affects all programs on the machine.
Note that for some changes to take effect you may have to minimize or even restart MicroStation.
