Product(s): | MicroStation | ||
Version(s): | V8i, CONNECT Edition | ||
Environment: | Windows | ||
Area: | DWG | ||
Subarea: | General |
How to store DWG settings that will be used on a number of files.
In MicroStation, a DWS file is a user preference file that stores DWG settings.
The file contains settings for opening and saving DWG FILES and is located in your workspace.
The configuration variable MS_DWGSETTINGSFILE sets the location of the DWS file and can be found here:
Workspace > Configuration > MS_DWGSETTINGSFILE
In the Save As DWG dialog, pick the settings needed and use the save icon in the Save As DWG/DXF options dialog to save the file in DWS format.
Now anytime you save to a DWG, this settings file will be used.
Opening and Saving DWG files in MicroStation V8
Original Author: | Derval Canny |
