| Product(s): | ProSteel | ||
| Area: | External Partlist | ||
| Subarea: | Partlist Creation dialog | ||
This section contains the wikis related to the Partlist Creation tool in ProSteel CONNECT Edition. This tool used to generate a partlist database (*.mdb) from currently selected steel objects and can be accessed under the Steel workflow > Data/Reporting > Reporting > Create Partlist Database.
Key-in: PROSTRUCTURE CREATE PARTLIST
