Here are the steps to create a hammerhead pier with circular columns:
- Open Substructure module and navigate to Geometry tab, open Pier Config dialog:
- Set the Pier Type to Multi Column,
- Cap Shape as Tapered and
- Column Shape Round.
![](bb5480454739c2909091861f536d431e.iix)
- Click on Cap and set the Tapered Cap Geometry (see example below):
![](4c64444d1b798a90f3fc5287624bcbd5.iix)
- Click on Column and set the desired column dimensions (see example below):
![](0464444d1b798a90f3fc5287624bcbda.iix)
- Click on Footing and set the footing geometry:
![](146480454739c2909091861f536d434a.iix)
![](5864844d1b798a90f3fc5287624bcb5e.iix)
