| Product(s): | InRoads | ||
| Area: | General | ||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
After receiving a set of cross sections that were created in InRoads 8.5, they are not recognizable in SELECTseries 2, how can this be rectified?
This can be rectified by using the Graphics Translator command. This command is located at File>Translators>Graphics Translators. This is an Application Add-In, so you may have to select Tools>Application Add-Ins> Graphics Translator Add-In first, and then invoke the command.
