| Version: | 08.11.09.459 | ||
| Area: | Custom Linestyles | ||
| Subarea: | N\A |
How to copy an existing linestyle and keep it in the same resource file so the user can then modify the text component.
Once the linestyle has been duplicated you will have a duplicate point
and stroke. At this point you can then make the modification to the
linestyle that you want.
Once the modification is made.
This will link the components to the new linestyle that has the modified
component.
