How to merge the reference into master?
 Product(s):ProSteel
 Version(s):CONNECT Edition (10.XX.00.XX)
 Area:N/A
 Subarea:N/A
 Original Author:Vyanktesh Nama, Bentley Product Advantage Group
Steps to be follow
1. Open Configuration Variable dialog and search for PS_DISABLE_REFERENCEMERGE.
2. Double on the variable to edit and change the value from 1 to 0 to enable the option.
With this you can now merge the reference into master.
NOTE: The grouping of the objects get lost by using this Merge Into Master option.
