Click here for readme and requirements
Release version 15.04.01
The following is a list of the major new features delivered with this release:
- General Updates
- Copy Security is now updated when performing Bulk Update activities and the Bulk Document Updates / Manage Attributes feature has been expanded to include 'Change Attribute Security'. The new feature allows the user to select attributes and to either 'Add Security' or 'Remove all security'
- The Director User Interface has been updated so that it can now use the new Quick Reporting and Intermediate Search features.
- The Prototype, Markup or Change Notice object now has a topic that provides a link back to the related Change request.
- The Copy Wizard has been enhanced to show progress status while copying similar to that shown below, please refer to the section labeled Setting up a community to copy objects for details on how to correctly install this feature. When the user initiates a copy a server job is now created to ensure the copy completes even if the client disconnects. This is accomplished using the CopyObject engine and is needed in a community where objects are copied. With the updated interface the users will see progress-bars/please-wait messages, and 'copy pending' information on the destination object.
- CADConnect Updates
- When creating a new eB Document from CADConnect users can now select a template using either Code or Class
- CADConnect now supports specifying a rendition size when printing to PDF
- eB Outlook Connector Updates
- eB's Outlook Connector only supports Microsoft Office 2010
- eB SharePoint Connector Updates
- eB's SharePoint Connector now supports Microsoft SharePoint 2010
- eB Web Updates
- eB Web now supports relationships for equipment, installed equipment and installed serial numbers for tags
- eB Web now supports quick and intermediate searches that are customized in either Director on Engineering Designer
- eB Web now supports two word searches in search criteria without requiring double quotes
- eB Web Quick links have been expanded to support Quick links for eB Reports
- eB Web now launches files in "Read-Only" mode.
- eB Web now supports adding objects contained in a folder to a user's basket
- eB Web now provides a warning message if a file upload or download times out.
- eB Web now supports selecting the document copy when publishing or distributing documents
- eQL Updates
- eQL has been updated to include the ability to build a report using the latest or latest approved version of a tag in Director, Engineering Designer and eB Web.
- eB Human Performance Including Corrective Action
- The Save, Save and Close, and Complete buttons now have configuration options to control the button text and to provide tooltips
- The Observations Wizard has been upgraded to include features that allow a user to easily add Trend Codes to a Survey Answer
- Print and Renditioning Updates
- eB now supports using ProjectWise InterPlot Server (V8i SELECTseries 2, as of this writing) as the printing and renditioning engine, which can be configured in place of the older print and rendition engine. For this release eB defaults to the prior print and renditioning configuration to ease the transition for existing clients. For product information, see: http://www.bentley.com/en-US/Products/ProjectWise+InterPlot/.
Note: A newer version of ProjectWise InterPlot Server is now supported in SELECTseries 4 (15.6.1).
- Search Updates
- The search for affected objects and documentation to be included in a Change Order no longer returns unapproved or historic objects and documents that cannot be added to the Change Order
- eB is now integrated with OpenSearch which provides the ability to add eB Searches to Windows Explorer as supported browsers.
- Documentation Updates
- Updated schema delta documentation now includes:
- 14.6.2 and 15.2.1
- 15.2.1 to 15.2.2
- 15.2.2 to 15.2.3
- 15.2.3 to 15.3.1
- 15.3.1 to 15.3.2
- New eB (Director) Administration Guide
- Updated documentation for eB managed SharePoint workspaces
- Updated Server install manual (obsolete, content moved to the new eB Implementation Guide in SELECTseries 4 (15.6.1))
- Updated eB for SharePoint documentation (obsolete, content moved to the new eB Implementation Guide in SELECTseries 4 (15.6.1))
- Updated Office Merge Documentation
- Updated eB System Management Console Guide that include changes for the InterPlot engine
- eB Outlook connector Installation and User Guide
- eB SSRS Data Provider
- eB ETM Installation Guide (obsolete, content moved to the new eB Implementation Guide in SELECTseries 4 (15.6.1))
- eB for Engineering Designer Install and Admin Guide (obsolete, content moved to the new eB Implementation Guide in SELECTseries 4 (15.6.1))
- eB CADConnect User Guide
- eB Bulk Transfer Utility
- eQL Report Designer Guide
